What is Guest Network and how do I set it up?
Guest network gives easy internet access for your guests.  It’s simple to set up a separate Wi-Fi network for guests and share access details via the app.
Go to the Guest Wi-Fi tab and tap on the slider button to turn Guest Wi-Fi  on and then follow the on-screen set-up instructions.
You must create a password to enable your Guest Wi-Fi network. And you can also choose a new name for your Guest Wi-Fi, which will be displayed when guests are searching for a Wi-Fi network to connect to.
You can tell your guests the Guest network name and password, or send them the login details by clicking the Share Login Details and then selecting how you wish to share this from the options given (for example, by email or Text message).
You can also set a schedule for when your Guest Wi-Fi network will be available to guests. Just tap on Schedule in the Guest Wi-Fi tab and select the dates and times for On and Off periods.
See video for simple set-up of a Guest Network:
Thanks for your feedback
Submit
Need more help?
