Fix TNT Sports player errors
This article is for people getting an error message watching TNT Sports on a computer browser.
Please type the error code in the box below to get the help you need (the more of the error code you type, the more relevant the help shown will be). If you don't have a specific error code or can't remember it, then click instead on the 'View all error help' button.
Problems without error codes:
Video doesn't play back when pressing play
I’m being blocked from streaming because I’m outside of the United Kingdom(UK)
If the online player doesn't work when you press the play button, it may mean that you need to change the cookie settings.
The TNT Sports online player uses cookies to enable a high quality viewing experience. You'll not be able to watch any TNT Sports online content if you have certain cookie restrictions; please follow the instructions below.
Remember, you can always change your settings back after you’ve finished using the TNT Sports online player.
Safari
  1. Go to Safari > Preferences > Privacy
  2. From the four options for 'Cookies and website data', please select 'Always Allow'
  3. Close the menu and then refresh the page. The player should now work
Always allow cookies and website data
High Sierra Safari
  2. In 'Website tracking', deselect 'Prevent cross-site tracking’
  3. In 'Cookies and website data', deselect ‘Block all cookies’
  4. Close the menu, and then refresh the page. Login and the player should now work
Prevent cross-site tracking and block all cookies
Chrome
  1. Paste chrome://settings/content/cookies into your browser
  2. From the three options for 'Cookies', please select 'Allow sites to save and read cookie data (recommended)'
  3. Make sure the remaining two options are de-selected. Your settings should now match the picture shown below
  4. Close the menu and then refresh the page. The player should now work
Edge
  1. Go to Settings > View Advanced Settings
  2. Make sure cookies aren't blocked (as shown in the picture below)
Don't block cookies
Firefox
  1. Go to Menu > Options > Privacy & Security
  2. Under ‘History’, select ‘Use custom settings for history’ from the drop-down menu
  3. Put a tick in the ‘Accept cookies from websites’ option
  4. Select 'Always' from the 'Accept third-party cookies’ drop-down menu
  5. Close the menu and then refresh the page. The player should now work
Internet Explorer
  1. Go to Settings > Internet Options > Privacy
  2. Under ‘Settings’, click the Advanced button
  3. Select the ‘Accept’ option under 'First-party Cookies' and 'Third-party Cookies'
  4. Click OK, then close the menu and refresh the page. The player should now work
Accept First-party Cookies and Third-party Cookies
I’m being blocked from streaming because I’m outside of the United Kingdom (UK)
TNT Sports can only be streamed in the UK. If you're outside of the UK, you'll be blocked from streaming any content.
If you're in the UK but still being blocked:
Make sure you're not using any VPN software on your device. If you do have it, manually configure the app or software, or uninstall to allow TNT Sports streaming.
We use the location of your IP address to confirm that you're somewhere that TNT Sports streaming is supported. VPN hides the true location of the IP address you're using, so the IP address it's supplying you with could originate outside of the UK.
Thanks for your feedback
Submit
Need more help?
