If your contacts are stored on a smartphone or a computer, you need to export these into a .vcf contact file. Once you have the .vcf file, save it to a micro SD card that you insert in the BT home Smartphone. Once you've inserted the micro SD card, follow these steps:
- Touch Contacts
- Press the Menu button
- Touch Import/Export
- Touch Import from SD card
Your phone will read the contacts and add them to the contacts list.
Tip: If your contacts are already saved to your email account (example Gmail contacts), your contacts will display automatically as soon as you add the email account to the phone by doing the following:
Press the Home button and then the Menu button
, touch Settings, touch Account and sync, touch Add account and follow the instructions.
