Back
Everyday Phone with Answer Machine
Our product pages give you product specifications, links to user guides and other documentation, plus helpdesk and support information where applicable.
Product details
Cordless phone with basic call blocking and answer machine
  • Blocks up to 20 numbers
  • Excellent sound quality
  • Easy set up
  • Long range reception, up to 300m outdoors, 50m indoors
  • Up to 10 hours of talking OR 100 hours standby time
  • See and hear if you have a second call waiting
  • See who's calling before you pick up
  • Easy to read screen shows when you have messages
  • Do Not Disturb mode
  • Save up to 50 contacts
  • Redial any of the last 20 calls you made
  • 1.6 inch amber screen
Recycle Logo
Documents
Thanks for your feedback
Submit
Need more help?
