11ac Dual-Band Wi-Fi Dongle 610 Windows software
To manually download the software for your 11ac Dual-Band Wi-Fi Dongle 610, click on the link below. Choose 'Run' to install the software or 'Save' to save and then run it later.
When you run the installer your screen will dim and you will be asked to confirm that you want to run the installation. This is normal.
11ac Dual-Band Wi-Fi Dongle 610 software
Note that if you're using a company laptop, you might need administrator rights to be able to install the software.
Thanks for your feedback
Submit
Need more help?
