The recordable TV box from BT comes with a 500GB hard drive. This will store up to 300 hours of Standard Definition (SD) TV, or about 125 hours in High Definition (HD).
The 4K recordable TV box from BT also comes with a 500GB hard drive. This will store up to 300 hours of Standard Definition (SD) TV, 125 hours in High Definition (HD), and 30 hours in Ultra HD (UHD).
How do I use the TV guide and record programmes? >
If you have the TV box (pictured right), you won't be able to record live TV. If you'd like to upgrade to a recordable TV box, please get in touch. |
