Back
How can I manage my BT Mobile bill?
We've got some handy tools to help manage how much you spend:
  • You can set a cap to control how much you want to spend on top of what you pay for your plan each month. You can change that any time by logging in to www.bt.com/mymobile >
  • We limit what you can spend on data while you're abroad to £40. You can also change this at www.bt.com/mymobile >
  • We'll text you when you're approaching your limit and then again when you hit it
  • You can keep an eye on how much data you're using with the My BT app
Thanks for your feedback
Submit
Need more help?
