Back
Set up and use a Digital Voice Adapter
This article is for customers who want to set up the Digital Voice Adapter they’ve received as part of the move to the Digital Voice service.
About the Digital Voice Adapter
When your landline service moves to Digital Voice, you may want to keep using your current home phones. If your phone is near your Smart Hub, you can  plug it into the green port on the back of the hub.
However, if you want your phone to be in a different room to your hub, you can use a Digital Voice Adapter to place it wherever you want in your home.
Any phone of any age will work with your Digital Voice service, either connected to your hub or an adapter, if it is a tone-dialling phone.
Visit this Digital Voice Adapter product page for a downloadable PDF of this device's user guide and details of its specifications and Declaration of Conformity.
The Digital Voice Adapter plugs into any mains power socket or cabled extension and syncs to your hub as a wireless extension.
Set up your Digital Voice Adapter
Before you start, check that there is a steady blue light on the front of your smart hub.
For ease of setup, plug the adapter into a power socket near your hub. The adapter will flash for 0.5 seconds on and 2 seconds off when you plug it in.
Then the steps to set up are:
  1. Press the WPS button on your hub.
  2. Within 1 minute of pressing the WPS button on the hub, press and hold the WPS button on the side of your adapter. The green light will flash quickly, 0.5 seconds on and 0.5 seconds off.
  3. Once registered with your hub, the green light will stop flashing and show a solid green light, indicating it’s ready.
  4. You can then unplug it and move it to wherever you want your phone set up.
  5. Plug your adapter into power again and the phone handset into the adapter, and you’re all set.
The green light on your adapter will flash when you’re on a call and go solid green when the call ends.
Once registered with your hub, your adapter will remember its link, even if you unplug it and move it elsewhere around your home.
Using your Digital Voice Adapter
You can use up to a combination of 5 adapters and Digital Voice handsets to have a phone where you want it. Your adapter is guaranteed for 1 year from when you bought it – we’ll either replace or repair it. However, if you have an issue more than 28 days after you bought it, we might replace it with a refurbished or repaired one.
Deregistering a Digital Voice Adapter
Deregister an adapter from your hub
If you need to remove or deregister your adapter from your hub and don’t have any Digital Voice Handsets registered, you can do this from Smart Hub Manager.
You can access it from any device connected to your hub. Open a web browser and browse to 192.168.1.254. Tap return, and this will open Smart Hub Manager, then:
  • Select the Phone tab
  • Scroll to the adapter you want to deregister
  • Select Deregister and follow the instructions
Deregister an adapter from a Digital Voice handset
From your handset’s menu:
  • go to Settings and press Select
  • scroll down to Registration and press Select
  • scroll down to Deregister and press Select
  • scroll to the adapter you want to deregister, and press Select
Thanks for your feedback
Submit
Need more help?
