Find out how easy it is to get a BT ID so you can run tests, report a fault, fix problems and book an engineer online.
Find out how to check your own telephone equipment with our helpful video guide, including checking the type of socket you're using.
Find out how to solve issues with your service including making and receiving calls or problems with your handset or extensions.
Go back to: What can we help with?
