Do I need to call my existing landline provider when I change to BT?
There is no need for you to contact your existing landline provider. After placing your order you should get a letter from your call provider, confirming your request to transfer. We'll then write to you after the transfer period, confirming the details.
Thanks for your feedback
Submit
Need more help?
