Back
All about Reminder Call
What is Reminder Call?
Reminder Call acts like an alarm clock on your phone - your phone will ring at the time you program it to.
Maybe you need a repeat reminder every day, or perhaps you need a one-off call to remind you to pick up the dry cleaning. You push a couple of buttons to activate the service and then enter the time and date you want to be reminded. Amending a Reminder Call is just as easy.
How much does it cost?
You can either pay each time you use this feature or pay monthly.
For our latest prices please go to the BT Residential Phone Tariff and type Reminder Call into the search bar.
How do I use Reminder Call?
Setting up a reminder call
Press the star (*) key on your telephone keypad followed by the number 55 and the star key again, the required time in 24 hour clock format (for example, 7.30am should be entered as 0730), and then press the hash (#) key.
Cancelling a reminder call
Press the hash key, the number 55, and then the hash key once more.
Checking the time of a reminder call
Press star, hash, the number 55 and then hash.
For more information on how to use your calling features you can download our user guide here.
Thanks for your feedback
Submit
Need more help?
