Back
Different types of BT Hub
Over the years, we've developed better and better Hubs (routers) for our customers as new technology has become available. This table shows the main differences between them......
Find what hub you have
BT Smart Hub 3
BT Smart Hub 3
BT Smart Hub
BT Smart Hub 2
BT Home Hub 4
BT Home Hub 5
Differences between each Hub
Compatibilty Mode
BT Smart
Hub 3
BT Smart
Hub
No
BT Smart
Hub 2
No
BT Home
Hub 4
No
BT Home
Hub 5
No
Complete Wi-fi (including Hybrid Connect & Digital Voice)
BT Smart
Hub 3
BT Smart
Hub
No
BT Smart
Hub 2
BT Home
Hub 4
No
BT Home
Hub 5
No
Number of antennas
BT Smart
Hub 3
7
BT Smart
Hub
7
BT Smart
Hub 2
7
BT Home
Hub 4
4
BT Home
Hub 5
5
Wi-fi bands (2.4GHz and 5GHz)
BT Smart
Hub 3
Dual band Wi-Fi 6
BT Smart
Hub
Dual band Wi-Fi 5
BT Smart
Hub 2
Dual band Wi-Fi 5
BT Home
Hub 4
Dual
Wi-Fi
BT Home
Hub 5
Dual
Wi-Fi
2.4GHz wi-fi band
BT Smart
Hub 3
3x3 11b/g/n
BT Smart
Hub
3x3 11b/g/n
BT Smart
Hub 2
3x3 11b/g/n
BT Home
Hub 4
2x2 11b/g/n
BT Home
Hub 5
2x2 11b/g/n
5GHz wi-fi band
BT Smart
Hub 3
4x4 802.11ax
BT Smart
Hub
4x4 11a/n
BT Smart
Hub 2
4x4 11a/n
BT Home
Hub 4
2x2 11a/n
BT Home
Hub 5
3x3 11a/n
Built-in 4G filters
BT Smart
Hub 3
BT Smart
Hub
BT Smart
Hub 2
BT Home
Hub 4
No
BT Home
Hub 5
No
BT Smart
Hub 3
4 x giga ethernet
BT Smart
Hub
4 x giga ethernet
BT Smart
Hub 2
4 x giga ethernet
BT Home
Hub 4
4 x ethernet
BT Home
Hub 5
4 x giga ethernet
USB ports
BT Smart
Hub 3
BT Smart
Hub
BT Smart
Hub 2
BT Home
Hub 4
BT Home
Hub 5
On/off light control
BT Smart
Hub 3
BT Smart
Hub
BT Smart
Hub 2
BT Home
Hub 4
No
BT Home
Hub 5
No
Removable password card
BT Smart
Hub 3
BT Smart
Hub
BT Smart
Hub 2
BT Home
Hub 4
BT Home
Hub 5
DECT
BT Smart
Hub 3
BT Smart
Hub
No
BT Smart
Hub 2
BT Home
Hub 4
No
BT Home
Hub 5
No
BT Smart Scan
BT Smart
Hub 3
BT Smart
Hub
BT Smart
Hub 2
BT Home
Hub 4
BT Home
Hub 5
BT Smart
Hub 3
BT Smart
Hub
BT Smart
Hub 2
BT Home
Hub 4
BT Home
Hub 5
Compatibilty Mode
No
No
No
No
No
No
No
Number of antennas
7
7
7
4
5
Dual band Wi-Fi 6
Dual band Wi-Fi 5
Dual band Wi-Fi 5
Dual
Wi-Fi
Dual
Wi-Fi
2.4GHz wi-fi band
3x3 11b/g/n
3x3 11b/g/n
3x3 11b/g/n
2x2 11b/g/n
2x2 11b/g/n
5GHz wi-fi band
4x4 802.11ax
4x4 11a/n
4x4 11a/n
2x2 11a/n
3x3 11a/n
Built-in 4G filters
No
No
4 x giga ethernet
4 x giga ethernet
4 x giga ethernet
4 x ethernet
4 x giga ethernet
USB ports
No
No
DECT
No
No
No
BT Smart Scan
Still need help?
For more advice on how to get the best from your BT Hub, visit Help for Hubs.
Or, if you’ve got one of our older hubs, why not buy our latest BT Smart Hub?
Thanks for your feedback
Submit
