Back
How do I change the wi-fi channel on my BT Hub
We don't recommend manually changing wireless channels on the BT Hubs as this turns off Smart Wireless. When Smart Wireless is on, the Hub will automatically select the wireless channel with the least interference, changing to a different one if it gets too congested.
If you think your wi-fi isn't working as it should, use our wi-fi checklist to help you get the best connection >
If you still want to make sure you're on the best wireless channel, we recommend you do a refresh rather than choosing a wireless channel manually.
This means the BT Hub will always choose the best channel available. And Smart Wireless will automatically monitor the channels to maintain a good connection.
Learn about Smart Wireless and how to refresh channels >
If you still want to change the wireless channel manually, click on the dropdown for your Hub:
If you decide to continue with manual channel selection, this will turn off the Smart Wireless feature.
  1. Open a new web browser on a device connected to your Hub and type 192.168.1.254 in the address bar. This will open the Hub manager
  2. Click Advanced Settings
  3. Click Wireless
  4. Enter the admin password. Unless you've previously changed it, you'll find the default password on your Hub settings card on the back of your Hub. If you have changed it and now forgotten it, you can use the password override feature to set up a new password without losing all your personal Hub settings and configuration
  5. To choose a specific wireless channel, you need to split your wireless bands. Change the separate bands switch to On. By splitting your network, you'll create a second visible network name for the 5GHz band. The new network name will have a "-5" to show it's for the 5GHz band
  6. With the wireless bands split, you can now customise your wireless settings
  7. Click on the "Wireless channel" box for the wireless band you want to customise
  8. Choose the wireless channel you wish to use and click Set
  9. Remember once you make any changes you will need to save them. Click Save
  10. After saving you will be prompted that as your wireless network name has changed, you may need to reconnect devices to the new network name
Learn about Smart Wireless >
  1. Open the Hub Manager by typing 192.168.1.254 in your web browser
  2. Click on Settings
  3. Enter the admin password. Unless you've previously changed it, you'll find the default password on your Hub settings card on the back of your Hub. If you have changed it and now forgotten it, you can use the password reset feature to set up a new password
  4. Click on the "Advanced Settings" tab, then click Continue to Advanced Settings
  5. Click on the "Wireless" tab
  6. To manually select the wireless channel for the "2.4 GHz" band:
    • Go to the 2.4GHz page and select a channel from the drop down menu next to "Wireless Channel". First try channels 1, 6 or 11
    • Click Apply to confirm the change. Then wait 60 seconds for your computer to automatically discover the new settings. There's no need to change any settings on your computer
  7. You can do the same on the 5GHz page to change your 5GHz wireless channel. We recommend selecting channel 36, 40, 44 or 48
  2. If this is the first time you have visited the Hub Manager you will be asked to change the password
  3. Click on Settings and enter your password if required.
  4. Click on the Wireless tab
  5. Find the Channel Selection option and using the drop down menu you can choose a new channel. First try channels 1, 6 or 11
  6. Click Apply to confirm the change. Then wait 60 seconds for your computer to automatically discover the new settings. There's no need to change any settings on your computer
Still need help?
For more advice on how to get the best from your BT Hub, visit Help for Hubs >
Or, if you’ve got one of our older Hubs why not buy our latest BT Smart Hub? >
Thanks for your feedback
Submit
Need more help?
