How can I check for firmware updates?
From the app, select Settings and then Firmware Status. The current firmware version number is displayed together with the "Last Updated" time and date, select Check for Updates.
If an update is available there will be an option to Update Firmware, select this and follow the instructions.
Please ensure all your discs are switched on and connected, before attempting to update the firmware.
Thanks for your feedback
Submit
Need more help?
