Your hub is starting up
BT Smart Hub 2 - Green Light
Wait at least three minutes for your hub light to turn blue -
which means it's connected
1. If your hub stays green, turn the power button at the back off and on again
2. If your light still doesn’t turn blue, reset your hub back to its factory settings - how it was when you first got it.
3. Use a paperclip to press the factory reset button at the back of your hub for 20 seconds
4. Wait five minutes for your hub's power light to turn blue, which means it’s reset
5. To reconnect to your devices find your WiFi network name and password on the back of your hub, then on your device search for your network name and enter your password.
