Buttons and sockets on the Openreach fibre modem
The Openreach fibre modem has been specially designed to work on our fibre optic network.
If you have Fibre to the Home, have a look at Fibre to the Home: Check your wiring and set-up for information about your modem.
Otherwise, click on the equipment that matches what you have at home to get the right advice:
Select this if your modem looks like this: Openreach fibre modem
Select this if your modem looks like one of the below:
Openreach fibre modem Openreach fibre modem
Thanks for your feedback
Submit
Need more help?
